association-list
interface-config-radio-instance
Associates an existing global association list with this radio interface
An association ACL is a policy-based ACL that either prevents or allows wireless clients from connecting to a managed access point radio. An ACL is a sequential collection of permit and deny rules that apply to incoming and outgoing packets. When a packet is received on an interface, the controller, service platform, or access point compares the fields in the packet against the applied ACLs to verify the packet has the required permissions to be forwarded. If a packet does not meet any of the criteria specified in the ACL, it is dropped.
Syntax
association-list global <GLOBAL-ASSOC-LIST-NAME>
Parameters
association-list global <GLOBAL-ASSOC-LIST-NAME> Associates an existing global association list with this radio interface
ap505-133E1C(config-profile-testap505-if-radio2)#association-list global test
ap505-133E1C(config-profile-testap505-if-radio2)#show context
 interface radio2
  mesh client
  antenna-elevation 5.0
  antenna-gain 12.0
  aggregation ampdu tx-only
  aeroscout forward ip 1.23.4.56 port 300
  antenna-mode 2x2
  antenna-diversity
  assoc-response rssi-threshold -128
Related Commands
no (radio-interface-config-command) Removes the global association list associated with this radio interface
